Results 1 to 10 of 223
Thread: my `76 GOLF 3dr
    Oakleigh VIC
    Quote Originally Posted by intensem1 View Post
    I cant believe they do you for like a torn boot seal what does that matter.
    That requirement was put in place because pensioners in Vans were monoxiding themselves to death when they hit the highways post retirement.
    In some cars there is a positive (or is it negative?) pressure zone setup behind the tailgate which can draw exhaust fumes into the cabin through a faulty hatch seal. The door seals don't get the same attention, it's only the hatches on vans and hatchbacks.
    Pete
    Jun 2007
    Eastern Suburbs Melbourne
    Pete
    Yea thats what the guy has said.
    I think the seat belt I might borrow off someone, just for roadworthy, and then look for amore permament solution later on.
    I have 7 days to mee the point on the RW slip, otherwise I have to pay another 70 bucks to get it done later on.
    i like volkswagens
    Oakleigh VIC
    Time to Pull Josh's car apart and find out how roadworthy his bits are
    Seriously though - get that seat belt sorted asap. You don't want your passenger messing up that new windscreen by trying to exit the vehicle through it.
    Pete
    Jun 2007
    hahaha, you're a funny fellow pete.
    More to the point though, I don't want me going through my nice new windscreen!
    So I will be looking for a better alternative for the long run atleast.. I'm going to go give Dean a visit and see what my options are.
    Headlight and number plate light issues seem to be fixed (just need new globes) as does the rear hatch seal, although I may need to silastic the joins on the section I glued in. I checked witht he guys, the seal can have crack, ie joins in it, So hopefully what I've done there will be good enough.
    just the wheels I need too. and fix up the suspension. and I'll be seaworthy! or roadworthy as the case may be
    i like volkswagens
    Feb 2006
    Camberwell, Victoria
    Bad luck buddy!
    I was just down at VP myself today about roadworthy's... Cause my car is poo! (your car is looking better than mine at the moment)
    I read the guide online. Essentially a RWC is not a document to say the car is 100% mechanically good, just safe to drive on the road.
    I am very suprised about the tyre thingo! In victoria, you are allowed to have wheels no wider than 2" from standard. Diameter is not the issue. lol. were your stockies 13x4's? LOL!!!
    Bad luck with the seal thingo!
    Talk to dean! He's straight to the point and very helpful!
    You're almost there dude!
    ROCK ON!
    Jun 2007
    did yours look like complete stock? stock wheels, black bumper etc? cause I think I may have seen it!
    Yea the wheels thing is wack. he mentioned something about the offset being different, and causing the wheels to scrub and thats the unroadworthy part. meh. I should be able to get it fixed...
    Unfortuntaley with the seat belts, there aren't many options. buy a brand new one for $160 from VP or don't pass roadworthy.. I'll probably borrow one for the roadie, and buy a new one later on.
    i like volkswagens
    May 2006
    Maryborough Vic
    Talking
    vic rwc's can be alot of fun
    you would find most cars with mags would be unroadworthy
    you can not increase the trac on a macpherson strut front end !
    but most roadworthiers don't look to hard
    but spacers a big no no !
    and your wheel not aloud to touch any part of gaurd in out lip nothing
    they can even ping you for the seal across the rain tray that seals bonnet
    cause you can get engine fumes into your vent system
    over all i think you did pretty well
    not a huge list
    and that 7 days thing is a bitch
    that vic roads for you
